agreed to above, stock RTR servos are never strong or fast enough, i really liked the Hitec HS645MG in my T-maxx for steering and ended up just using them all over, and are well priced for the quality.
well guess this is difference in opinions, i would not recommend fuel filters, just take care when fueling to not get debris in the tank or fuel bottle. close caps, when not in use, wipe off dust etc, fuel filters are very liable to get an air leak (especially the really cheap ones) which will reduce fuel pressure making the engine run lean. also when they start gumming up, after sitting they will do the same thing by limiting the fuel flow.
when they work, they work great, when they dont, they really dont in my experience. by all means though definitely worth a shot, you may have betterexperiences than I did.
that is really strange with the air cleaner getting sucked inwards never seen that happen before.
the pre-load spacers are mainly just to tune ride height. the springs themselves are there to return the truck to ride height and the oil is the dampener. so if its feeling bouncy/springy like bad struts in a 1:1 car, get thicker oil, if its really stiff and slapping the ground and pogoing back up, use thinner oil. i found 40-45wt worked great in my T-maxx back in the day, but some liked thinner around 35wt, some were using up to 60.
if its sitting lower than you want, but still has good dampening and returns to its ride height acceptably (though maybe not the desired height) add a few of the preload spacers to get to the height you want. they arent necessary per se, though most i have experienced need some. the best height for power transfer is what is called "bones level" where the axles are flat to the ground, but for bashing a higher ride height is typically preferred because usually bigger jumps than racing.
all that is personal preference and what you want out of it though.
pretty cool noticed you have the steering servo skid plate and center skid plate in your pictures, nice mods there! careful with them aluminum bumpers though, they are not friendly if you happen to hit your ankle lol
