trouble binding new flysky receiver
krazymatt
I was trying to bind a new flysky receiver and transmitter and could not suceed. The radio Powers up and appears to work fine but cannot get it to bind. I tryed two extra receiver boxes i got with it. Any ideas? I understand the flysky is a cheap product so that might be the issue. Thanks
Lets make sure your doing it right first....
3ch rx.
With your radio turned off
Plug the bind plug into the BIND/CH3 port
Power the rx through any of the other Ports (with esc, bec, 4 AA rx pack, etc)
Click and hold the BND button on your radio
Turn the radio on
The red LED in the rx should go solid
Let off bnd button, pull out the bind plug
pull power to rx and shut off tx, turn both on make sure you get a solid red led
Hope what lloyd said to do works for you. I had the same problem and sent it back after trying 3 different receivers.
Sent from my Samsung Admire
I only had one problem with all my Flysky stuff and figured out i went stupid and wasn't doing it right, i have 10 so far and all are working great.
Thanks for the help. I was using the wrong bind port. Got it going!:)
