Traxxas Slash 2WD turnbuckle question.
biggman100
Corning, NY
Does anyone know if the turnbuckles from the 4WD and 2WD Slash are the same? I found complete Traxxas kits with blue turnbuckles, with all 7 included, for the 4WD, but, the only blue 2WD ones i can find you have to buy them somewhat separately, but, i thought someone awhile back said the 2WD and 4WD used the same ones.
I think they are interchangeable. The easiest way to know for sure is to do a quick cross reference of the part numbers.
The part numbers for different, and, after a ton of searching, i found a stock 2WD Slash setup sheet, and the ones on the 4WD are different lengths than the 2WD, from what i can tell. I can't find a set up sheet for the 4WD to check the measurements, so i could be wrong.
