Throttle not closing and staying half way open when I hit brakes
iamnotsmart
RCTalk Qualifier
Why is my nitro rustler staying open after I hit brake then close when I hit throttle does anyone know it’s a nitro rustler if anyone knows let me know thank you idk if there’s a spring for my nitro rustler I’ve been fixing one and recently put a dynamite .19 in it
Sounds like the linkage points slipped, or the throttle trim got adjusted by mistake and doesn't return to neutral. You can make those adjustments without starting the engine.
A throttle return spring could solve it
New servo or return spring.
Yeah I will have to look just installed a new engine and when I hit brakes engine stays open half and after hit throttle stays closed it’s weird
The carb may be binding. Usually fix that by rotating the carb/carb arm. You want the throttle wire to be as parallel to the carb slide motion as possible. Unless it's a rotary carb, then you want it as perpendicular to the pivot direction of the carb arm as possible.
This is on traxxas' site for the 2.5 linkage and honestly, I'd rotate the carb a few hours clockwise so the wire was more parallel with the slide action:
Having it how they show it would cause it to bind after a while more than likely. Especially with the composite carb they use.
https://traxxas.com/support/Throttle-and-Brake-Linkage-Adjustment
SiN360
4
Weezel
Weezel
normrdz300
4
3K
normrdz300
normrdz300
yfzracer450
16
yfzracer450
yfzracer450
therealjimmyyy
9
therealjimmyyy
therealjimmyyy
