That looks awesome!Working on bridge for 30. 10 pack 12in 3/8 dowels. 4 3in sections from each dowel. Dremel to give the look of "logs"
You need a tool to pull the pinion?If you decide to stay brushed, go with a Holmes 050 motor. This one is a 55t and the description says it has neodymium magnets. Comes with a 12t .3 mod pinion that is rather long so swap on your stock pinion. Same speed as the stock motor roughly, and way smoother.
The Meus pinion puller tool is $20 and worth every penny. I have a couple other cheap tools that are just ok.
The smaller ones I can generally pull with a little heat on the pinion.You need a tool to pull the pinion?
Yeah. Sometimes I even add a tiny drop of superglue. Just depends.Are they just pressed on? No keyway?
Thats somewhat disappointing but I guess they are pretty tiny.Yeah. Sometimes I even add a tiny drop of superglue. Just depends.
They are plenty tight enough not to slip. Ya gotta figure, all the stress is in the trans. The pinion has very little load on it.Thats somewhat disappointing but I guess they are pretty tiny.
Most of the time. I have only pulled off a plastic pinion without a tool. If you can get a small screwdriver underneath, it is possible to pry it off. Rumor has it though it can potentially damage the innards of a motor. If you can make something that pulls on the pinion from underneath and pushes on the shaft, that's what the tool does.You need a tool to pull the pinion?
Flex blades? Love that K10 body!Went to my LHS yesterday.
Picked up the blue Bronco for my youngest daughter and my buddy picked up the black K10
Put some flex blades on the rear of the Bronco
View attachment 265341View attachment 265342View attachment 265343
Flex blades - https://makerworld.com/en/models/2144582-scx30-flex-blades#profileId-2376742Flex blades? Love that K10 body!
They look like they will. They didn't seem to want to work on the front of the Bronco, just the rearNice! I saw injora I think makes them. Some online retailer was selling them. Looks like it made a huge difference. Will they work on all the models?
I ran some homemade ones on my first 2 24s and they were quite capable. But I also run no springs with a droop set up.Flex blades are great for static flix shots. But for actual crawling, they just make the rig top heavy and floppy and nothing more.
