T-Maxx chassis? Has anyone ever seen a T-Maxx chassis like this? I can't find any info on it.
BigHoss
GA.
  3. Crawling
  4. Scale Builder
  5. Flying
  6. Boating
Help. I can't find any information about this chassis.
View attachment 141449Help. I can't find any information about this chassis.
I know extremely little about the T-maxx, but after 60 seconds of Googling, this chassis looks to be the same, best I can tell, only yours is silver, and the one linked to is blue. You can also apparently get it on Amazon. Here's what I searched for: https://www.google.com/search?q=T+M...=1.5&safe=active&ssui=on#imgrc=gQqpbzAwTxtWTM
Hope this helps!
Edit: Oh, and also, welcome to RCT!
am i missing something I dont see the shallow cuts as the amazon 1.
Huh? Keep in mind that the two are facing in different directions, so the left side of the chassis for the Amazon one on your screen is the right side for the other one.
Thank you. I believe that's it.
You're welcome! Glad I could help, any reason why you're looking for the chassis?
He saying the shallow areas . On mine there are holes .
It almost looks homemade to me. I say that becuse the rounded edge at the bottom, and straight edge up top, both on left of tranny, look wavy and notchy.
Not knockin the work, just doesn't seem like other tmaxx parts out there.
I will look today. Ue, dynamite, flm, and a bunch other companies flooded the tmaxx market early 2000s. Alot of products are no longer and some companies even went under.
That maybe a Hardcore chassy ,they are sought after but not sure if it is a big block conversion an
not sure if it is Hardcore brand.
Hardcore company moved on to make motorcycle parts!
Flm also moved to motrcycles. They do a few car parts and motocross I believe.
This chassis?
https://www.ebay.com/itm/185119077273
To me, it looks like someone made it... or hacked away at a stock chassis after deanodizing it. It's like they tried to mimic the traxxas 7075 chassis by cutting up the stock 6061 chassis. The traxxas 7075 chassis has beveled edges. Yours has the folded up edges like the stock one to add rigidity that the 7075 one didn't need since it's stiffer material. The rigidity the bends made was mostly removed due to the large cut out on the side on yours.
Just curious, why are you looking for another like it?
This chassis?
Thanks for showing that ,I know that Hardcore did some unique chassis ,I was just letting BigHoss know to watch
out for them!..👍😎
I agree with @olds97_lss definitely a stock Tmaxx 2.5 chassis thats been deanodized and cut up. I've had the Tmaxx since it came out. And yes there was a ton of companies that jumped on the Tmaxx band wagon. NO one made a chassis with that odd cut out on the left side. Good eye olds
I barely know the Tmaxx...🤣🤣 Now that you mention it, that cut is a little strange, and the cut edges and the bends/curves do look a little homemade.
