Redbeard
Can somebody explain? What changing a spring weight does to handling vs. changing shock oil? If I change the oil weight do I need to change the piston size? Should the front shock oil be heavier than the back? What about the spring weight in that situation? What effect does changing the shock mounting position have on performance?
Basically, I'm currently running the standard FTSC setup (with a havok and 8.5 brushless geared 87/17) on a tight small track, with small jumps It's half hard packed and half loose dry dirt and I'm not really happy with performance. Truck seems to bounce too much over the rhythm sections making the truck difficult to drive. Unfortunatly that's costing me time and speed which obviously affects consistent lap times. Any suggestions on setup adjustments that will allow a better "flow" and less bounce?
