If you don't ask a lot of it, it does fine. I ran the castle sct sv3/3800kv unsensored setup in my stampede 4x4 for quit a while on 2S. With 2.8" trenchers I ran with 13/52 gearing and it did ok. With 14T, it ran hot and would cog when I accelerated. With 2.8" chevrons and the stock vxl-3s/3500 system, it would overheat on me with similar gearing towards the end of a pack, but with the castle system and heavier tires, I could run pack after pack. I had a fan on the motor as well.
I started running 3S late in 2018 with the castle system and 11/52 gearing. Seemed to do fine, but it was cooler out. About half way through the pack, the throttle would feel a bit soft, guessing the motor was heating up by then. Early 2019, I busted the motor shaft, had the 1/8th shaft then and instead of replacing the motor, I got the hobbywing
max10 sct/3200kv system. I wanted to run faster than I could gear it though as I started running at a grass bmx track that had a lot of larger jumps that take a bit more speed to clear. And it being grass, caused extra drag/heat.
I've since installed a slash chassis and now run a 1/8th system on it with 3S. So far, it's working out well. Got a blx185 esc and 4076 2200kv motor in it with 19/54 gearing. Also put a center diff in it with FLM alloy diff cup and 500k oil, which helped calm the power a bit, but still add some driveline protection.
I post up a video of pretty much every bash I run and in the description/beginning of the video I list out the setup. Check them out if you want to see how the stuff I listed out did:
https://www.youtube.com/c/olds97lss
