well, it has Nothing to do with Bedazzleing as you seem to think it does. i ll leave that up to Miss South Carolina!!!
But it HAS everything to do with shareing Knowledge. WAY to many times you go into a thread and someone says Do that, Do this, That is your issue, but in no way tries to elaborate on the cause of the issue at hand.
now Yes glow plugs fail all the time on new and old motors. i have a motor here in my SIG QB P 51, that is older than dirt. its and OLD K&B 61, and has probably seen more fuel than my Safari Van that has 200,000 miles on it. it fouls out glow plugs too when its set too rich on the H needle setting.
Saying Change the Glow plug, is like telling someone with a non running 1:1 car to put gas in it. sure more gas COULD help, but its most likely NOT the cause of the car not running. the more you educate people the more they learn, and in turn share their knowledge with the next Newb.
i could be like most others and say change the glow plug, but would i be doing anything more than telling the OP to spend and extra 5 bux he may not need to? not likely.
if it is running with the ignitor on it, then 98% of the time the glow plug is working fine. so that leaves the next logical option, the motor is jetted rich, so to Lean up the H needle by on HR and see if it will now idle WithOut the Ignitor attatched, is the next thing one should do.
have i had a glow plug work with the igniotor and not work with out it on a normally well tuned motor? sure i have, but its the exception to the rule in my experience. in most cases, the tuning is Just a tad to rich, and the glow plug is fine.
its about shareing knowledge and experience. thats all.
the more you less you blow.
T
