Havas
Hi all,
Excuse my first post here being for help but I'm in a bind!
It's been a long time since I last owned an RC car but I just bought myself a sportweks mayhem ST two days ago and It's got an issue that I can't seem to pinpoint.
I managed to get through almost 3 tanks before the following issue occurred, I followed the instructions to the dot during the run in and then it stalled and after that point when I try to start it all the wheels spin sometimes it happens and sometimes it doesn't and when it does start without the wheels spinning and I place it on the ground it would die after a min or so, at this point it's hot but not scalding hot.
Could the clutch be gone already? After only 2 and a half tanks? And another thing is when I put it on the ground and try to push it forwards it's stuck it wont go, the brakes are not on because I've checked that and removing the engine causes it to move forwards just fine with all the gears working etc. And I can spin it manually with the engine out although it's a bit stiff but when I couple the engine back to the car there is a grinding noise, the noise does not occur with the engine out when turning the engine or spinning all 4 wheels on the car only when they are all in place does the noise occur and I can't see anything touching anywhere, I've gone over it with a fine tooth comb.
Any help would be appreciated I'm hoping it's a simple fix otherwise I have to take it back down to the shop.
