Background Info: I've been running Nitro RC's and now I'm trying out with my 1st electric with an RC18T Kit. I've got a Mamba Competition X setup installed. Everything is ready to go. The only thing I need to do is to solder the esc black & red cable to a male Deans connector.
Few Questions:
1) I know I hear you guys recommending to tin the wires and to tin the connector. But how thorough do I tin the wires and the connector? How much solder should I be putting on? Does it need to be a big fat gob of solder or just a thin coat of solder?
2) Assuming that I know the answer to #1, when attaching the tinned wire to the tinned connector, how much solder do I need to use to attach it? And what's the best way to do this? Correct me if I'm wrong, but I'm trying to place the solder on top of the wire which lies on top of the connector plate. Once I have this clamped down with my clamping tool, I heat the solder, right? Does my iron physically touch the solder only or should I be trying to melt the solder by touching down the wire?
3) How hot should my iron be? I have a weller 40watt and I have it on setting 5 which is the highest. The solder melts in like less than a split second as soon as it touches the iron. Plus, it melts and burns so fast that there's a glob of solder on the underneath of my iron tip so that it stays cooked and turns brownish. Does this mean my iron is too hot and should I lower the temp?
4) Last but not least, when you solder, are you supposed to let the solder drip onto the wire or your connection or are you supposed to kind of brush it on as it melts? (Maybe this will give me a clue to my question #3)
Thanks in advance, I can't find any manuals on this stuff and they don't teach you this when you buy an electric car. Sucks.
Few Questions:
