You don't want to eliminate the slipper on a basher. If you do, it's a blown diff waiting to happen. (or some other drive line component) If you're eating up slipper clutches, then you most likely need to tighten it a little. The only time I've ever had a rig "eat" a clutch is if it's too loose, and it's slipping a lot. The heat that generates will destroy the slipper in short order. You only want the slipper to slip when the tires can't.What’s the thinking behind eliminating a slipper clutch? I’m just bashing a 4wd Rustler that eats clutches but if I eliminate that won’t the diff’s take a beating?
To a certain point, there are ways to soften the acceleration with punch as well as drive frequency, throttle speed and expo curves, but these more of a "fine tuning" sort of thing, there's no way you can get your electronics to make a locked spool feel anywhere close to 7K fluid in the center diff for exampleIf you eliminate the slipper, you can get a different ESC that will allow you to adjust the "punch."
