sleeve wont come out!!
freerida69a
my revo 3.3's sleeve will not come out! I've pushed, hard, on it and it wont budge! what can i do to get this sucker out?
well if its stuck then your screwed unless you wanna buy a new when you break it from prying it outta there...JMO
I always insert a zip tie above the piston into the exhaust port and then spin the flywheel and it comes right up.
Put it in the oven @ 300 degrees for 5-10 minutes. The heat will expand the case so you should be able to push it out with a wood dowel.
if you do this remember it's hot, be carefull not to burn yourself...... the dowel could easily slip off or something and your hand hit the motor.
