SCX24 vs FCS24 With Portals
Jamr
SoCal
  2. Crawling
  3. Scale Builder
  4. Boating
I was about to start my 24 fabrication and I was deciding to go with the SCX24 or the FCS24 with portals.
Anyone have any experience with the FCS24 portals?
Here is a vid of the two head to head.
Fcx axels are great. Especially if you can get the max smasher axels. They come with all the metal gears.
This must be the plastic version?
Does this truck have the steel axles?
https://www.amainhobbies.com/fms-fc...truck-w-2.4ghz-radio-blue-fmm12402bl/p1455185
How do you tell
The Fms fcx24 has plastic gears in its axels.
The Fms fcx24 max smasher has all metal gears in its axels.
https://www.motionrc.com/products/f...4gXwYtlxujdyExDq3R-b382TXlGxUU6DeuwDPjD16rLyY
https://www.motionrc.com/products/f...pKGcAh7I-GjZrMfIfSUmGVUx5qSaRfTDjsY4i2iWD_AMs
And the fms axel shafts are 3mm. Not 2mm like scx shafts.
What is the width difference if the FCX24 and SCX24 front axles? Can someone measure across the hexes for me? I have a custom build I want to start soon.
Got it. Thanks. I am going with the plastic for now. The metal ones are twice the price.
I do not have a FCX yet but the SCX is about 89mm.
@Doom! - can you get me the same measurement on an FCX24 axle?
I wish I had seen this before I left for work this morning, I would have brought one with me, I can get that for you tonight if that's not to late.
No rush man. I was just thinking about my 6x6 build the other day and may opt to use the FMS portals. The Smasher ones are awefully pricey though.
I'm not sure how all that works but if you go with the FMS portals you may have to adjust your gearing. I think portal gearing is different than standard. Anyhow I'll measure those for you tonight or I will forget.
Thanks bro. So that would probably be ok. I don't want the track width to get too wide, and that would actually be narrower than the Carnage with the flipped RC4WD spoked wheels and Treal +5mm hexes I think.
