Roog
- Keynsham, UK
- Crawling
- Scale Builder
I was gifted a beaten up Irvine .20 glow engine so I am planning to build a nitro powered tethered race car based on the classic 50’s style with a Grand Prix body from that era. It is intended that the car will have an RC throttle!
My first issue is that the engine came fitted with a centrifugal clutch which isn’t helpful because tethered cars are generally push started. So I need to make a new flywheel which can interface the pinion gear from a set of matching bevel gears.
The engine drive shaft is short so I have had to figure out how to fix the pinion gear on securely.
My biggest fear is making the split tapered collet and matching internal taper in the back of the flywheel. I’ve not had much luck grinding miniature boring bars to fit inside a 1/4” hole. But a friend on the UK model engineering forums suggested buying a ready made tool from Ali express, I was sceptical but it seems to have worked a treat. The first issue was it’s really small 4mm shank and I had to make a collet to hold it in the lathe tool post.
It’s only a little tool but it was quite rigid.
So here’s the first part built
Complete with pinion gear located in deep recess in flywheel. The flywheel will have a couple of drive pins set inside the recess to engage with a slot in the rear of the pinion. To get around the issue of the short drive shaft my friends from the UK tethered car club suggested I make a sleeve nut, (I had to look that up), so once I’ve had a go at making the split tapered collet to match the internal taper in the rear of the flywheel, the sleeve nut will be next on the list.
Just in case there is any confusion I bought the bevel gears, they are spares to fit a Hitachi angle grinder.
The plan is to make a sturdy sub chassis mounting the engine, the rear axle and locating the bevel gears which will be doing their best to push each other apart!
I’ll then consider how to attach the chassis rails and consider whether I want to pivot the subframe to introduce basic suspension.
