RPM Slash 2WD Adjustable Body Mounts & Posts
robmob
THE PEOPLE HAVE SPOKEN!
Community Leader
Napa, CA
http://rpmrcproducts.com/products/traxxas/Slash5.htm#bodymnts
Front - fits the Slash 2wd, Rustler & Nitro Rustler
Rear - fits the Slash 2wd, Stampede & Nitro Stampede
Front Adjustable Body MountsImmediately after releasing our Adjustable Body Mounts for the Traxxas Slash 4x4 (#73932), RPM customers with the 2wd version of the Slash wanted adjustable, more durable body posts too. RPM Adjustable Body posts for the Traxxas Slash 2wd are here and are designed for durability and strength while still allowing you to change the body height on the truck.
Our unique body post mounting system allows the option of using the stock body height on the chassis. The body can also be lowered as much as 3/16” or raised as much as 3/8” simply by moving the posts up or down on the mounts.
Rear Adjustable Body MountsThis simple, yet clever design is strong enough to handle the toughest of conditions while still allowing enough flex to absorb impacts that could otherwise damage other more fragile internal components of the chassis. Everything about our body mounts and posts are beefier than stock – from the thicker than stock screw mounts to the twin screws holding the body posts on to the mounts. We also use an I-beam shape throughout each mount, which provides the strength these parts need for those less than perfect landings.
Tech Notes: These body mounts and posts are fully height adjustable on the Traxxas Slash. For vehicles listed above other than the Slash 2wd, each part number may be used although adjustability may be limited based on the vehicle used.
81122 Adjustable Front Body Mounts
Available 10.20.10
81142 Adjustable Rear Body Mounts
Available 10.20.10
Suggested Retail
$9.95 ea.
