Redcat blacout sc pro
pyro0328
I recently got into this hobby, I was gifted a redcat blackout sc pro from a friend. I have rounded off the hex. I fear this is going to happen again. I ordered some metal ones from Amazon but the diameter of the hex was to small to fit the axle. Does anyone know what the diameter is or recommend any hex hubs for this rc.
Download the user manual for that rig and find the part number for the stock part in the exploded views. Then google search that part number. Sometimes you can find the info that way.
do you own a drill index? find the old hex use index then take drill and try to step hole up to that matching drill size.
then you can know what axel size is ..
Are you referring to the wheel hex? If so it's 12mm.
You can download the manual with the exploded views/parts list here.
https://www.redcatracing.com/produc...ric-short-course-truck?variant=31050558832730
The axel is 4mm. The hex is 12mm x 12mm. I do not believe they make a metal one of these that's compatible. Either get more plastic ones, which are cheap, or upgrade to a better brand like Arrma or Traxxas. Sorry, I tried. 🤷‍♂️ Good luck.
If it were me, I'd just do as tnt said and drill out the already purchased hexes to fit the axle. But I am sure there are 12mm hexes out there with a 4mm hole that would work. But these are a weird hub. What is the area behind the hex for?
the axel shaft he knows its the hex is 12mm.
He said the diameter of the hexes was too small to fit the axle, so I assumed he meant the inner diameter of the hexes. But yeah, it could be taken the other way I suppose 🤷‍♂️
