Yeah, that's a sub-c type pack. I'm assuming that you really want a 5 cell 2/3A hump pack:
https://www.rcplanet.com/batteries/...ry-6v-1700mah-reciever-pack-3-2-hump-dyn1461/
The receiver should have a fail safe if signal is lost, but I doubt it has one if pack voltage gets too low.
I'm not sure specifically which transmitter/receiver combo comes with it. If it's this one:
https://www.spektrumrc.com/Products/Default.aspx?ProdId=SPM2330, it comes with the SR310 receiver. To set the fail safe positions, with the receiver off, you need to put the throttle where you want it and steer the tires where you want them when the fail safe kicks in. Then you put the bind plug in, power it up, put the transmitter in bind mode. Once it links, you power it down, remove the bind plug, then turn everything back on. Now, if you use the remote to turn the wheels and the trigger to go WOT, shut the transmitter off and the servos should move back to where they were when you bound the xmitter/receiver.
