I would like to setup a safety relay for main power that is based on the receiver being actually linked with the transmitter. I am not looking for the normal failsafe. I would like the relay to be on any time the receiver is active and linked and off when the receiver is active but not linked. I can make half the functionality work with the basic failsafe in the sense that I can failsafe to turn the relay off when no signal or link is available. The issue is that when the receiver is linked again with a signal the relay will still turn on or off based on the PWM high or low. That means I can turn the relay off by changing the input value. What I really want is for the relay to be on with any valid signal high or low and off only when no valid signal is available do to loss of power, signal strength, out of range.
Any suggestions or ideas would be great.
Thanks for your help.
