Rc compatability
Just check the size of the shaft diameter and double check the pitch on the stock pinion and you will know. That is a 3S capable motor and esc yes.
Yes
Just for reference the size of the shaft is 3.175mm so 1/8 is close to it, should all work together no issues.
I have the same combos but I run on 2s and 4000kv and they rip.
Yeah I can't wait I just wanted to make sure, as I brought a esc and motor from a hpi Firestorm, and used a 3s and the esc set on fire 😅 i guess next time I will do more research when getting into a new hobby.
Yikes, time to invest in an infrared temp gun. Check motor and esc temps after a few speed passes or a couple minutes of driving. Stay out of the grass, it just causes the electronics to gain more heat.
