I have the MX-3 FHSS 2.4ghz system from Airtronics, and it is the perfect spread-spectrum radio for a beginner. The menus are intuitive; I didn't even have to read the manual to tell how to change EPA's and sub-trim and such. I had to look up the throttle curve thing simply because I didn't know what it was, but other than that absolutely no problems. It has 3 channels so you can use reverse if you have a MT. Pricing
It has an 18-model memory (it uses a numerical organization system; if you can't remember which one is which just put a small card in the battery tray with the models on it). The battery life is excellent, I can drive through at least 3 tanks on my Baja (that's about 2 hours) without it needing a charge, and there is a battery voltage indicator. Once it gets to around 9 volts I go to charge it but so far it's still on 9.8 volts after 2 hours.
As far as range goes, I can drive my Baja 5b so far away that I can barely even hear it (there's a 1-second delay between hitting the throttle and the sound reaching my ears...
) and still have perfect control. It's easy to bind and set the failsafe.
There are only four buttons for the menus: select keys to change the menu option, and +/- keys to change the value. Every menu has its own icon on the screen, so you can cycle through them all and know which one you're on at all times. There are hardwired toggle switches for throttle trim, steering trim, and dual rate.
I hope that helps... Sorry for sounding like a sales pitch, but I really like the remote, lol.
Ok, so apparently they discontinued the model that I have, but the new one looks to have the same features, and the same price. $150. Pretty low for a 2.4 system with the features it has
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXWYX8&P=7
