Radiomaster to Ultrix 600
TerrorDactyl
Has anybody already bound the TX16S to the Ultrix 600 as I got one and haven't gotten it to go right. Would appreciate any help. The only thing I found so far is where you use a bind plug and the Ultrix doesn't use one
after some research looks like your model goes into autobind 5-10 seconds after you connect the battery to model.. radio must be in bind mode then you connect flight battery it goes into bind mode then you disconnect planes battery turn radio off then back on connect planes battery again you should be set to fly..
EFL02250-Manual-EN.pdf (horizonhobby.com)
extinct one did you get it to bind?fyi to all the cloners your future dinosaurs clones will never survive they all will die from 02 starvation. put those million to a good use
The problem is that the TX16S doesn't stay in bid long enough in that setup
