Sure thing Buncrana,
I own a dirt oval track that, oh i'd say maybe 15 - 20 of us run AE GT's with a mixture of motors. For example we have some that run the stock AE 15, OS 15 CV and CV R, 12 CV and CV R and a few Fantoms. We don't race under a lap counter. We do it for the fun of it.
I do own a pinching machine that I use for pinching the guys sleeves.I don't do it for a business or for the money. Our "group" just likes to save $$where we can. We have no problem running pinched sleeves.
I have learned that a tight pinch kills a piston and sleeve in the long run. I've played with different pinchs from light to tight. Say what you like but what i have learned is this, the light to medium pinch at the top with a very light pinch just above the ports will make these engines last for 4-6 gallons. You see the compression stroke starts just above the ports. The fuel and oil mixture starts to seal the compression and the pinch holds the compression for the combustion. Also I have learned that better sealing just above the ports with a minimal drag and a light pinch makes a faster motor. Less drag on the piston and sleeve makes more RPMS. Now before you jump up and down, i have used only the engines that i have listed above, and the fuel milage and life of the motor depends on the person that tunes the motor. Some like to have a screaming motor where others like it a little rich. Rich seems to make the car a little slower but make the motor last longer. Screaming seems to wear out the piston faster. We have run sleeves that have been pinched 2-3 times and changed the con rod maybe once. After that we throw the motor away due to the fact that by the time you replace bearings, crank, and a new P&S, you can buy a whole new motor. I guess you could label us budget racers.
I could be wrong about the bigger motors like the .27's. I have never owned one. But, as big as they are i'm quite sure that they do have a tighter pinch. But not to the point where you have to use a drill motor as one person here stated he had to use just to turn it over with out a GP in it.
My findings and opinions are mine and in no way i'm I trying to offend anyone. I'm just learning as much as i can about different motors. I do appreciate all the info that has been posted. But what really impresses me is the respectable way that it has been done
