truggy83
Hello, I have just completed my project but it seems to have some tuning problems. First off I have adjusted the servo and linkage to where it closes all the way at the neutral position. Tell me if this gap looks ok for a good idle speed. This is with the transmitter and car on and in neutral.
Here is the position at full throttle. Notice how the Throttle only appears to open about half way instead of fully. I don't know how to fix this because if I move the rod so it pulls the throttle more, it than doesn't close the throttle enough in the neutral position. It is like you change the position of the rod and it changes both the throttle stop position and full throttle position. I don't know what to do.
Full throttle. Only open about 1/2 way.
Linkage at neutral position
Linkage at full throttle
Can you please help me so I can get this adjusted right now that I got all the right parts.
Actually in the very beginning of the video when she goes outside and you see it laying on the blue tarp is right after it wrecked and landed on the tarp breaking the shock tower. At the end it flipped and shut off however it did start back up and run until I called it quits. Didn't want to break anything else for the day.
