I'm having a hard time fitting my .26 RD to my thunder chassis
Lookin at the picco .28. What type/size clutch and flywheel do I need?
Also will the picco accept a mod 0.8 CB?
I have put a force .28 into a hyper chassised maxx no problems at all
I used the stock clutch, bell and flywheel I did however have to shim the flywheel away from the block but other than that its a rocket even with the standard gear
Ok so you were using .8 gearing? Illegal be using revo spurs with mod 1.0 CB
What are some brands or sizes of flywheels and budget friendly clutches that will work?
I dont see why you couldnt use a spur and cb from a revo the stock flywheel should fit most engines the only issue you may have is meshing the gears you may have to elongate the chassis holes to get everything to line up correctly
---------- Post added at 3:32 PM ---------- Previous post was at 3:29 PM ----------
I just remembered a while ago I bought a Robinson racing spur/cb kit from amain and its 1.0 mod 40t/18t cb wo I'm guessing it fits the maxx with no mods but I haven't mounted it as I only wanted the cb for my revo
I used the stock standard traxxas one the 40mm one doesn't fit
All that is needed to make the stocker fit is some shims and a clutch nut adaptor I'm not sure on the part number as I got with a parts engine when I was doing my bb build
The sticker is only a 2 pin flywheel I wanted to use a 3 shoe clutch Will 34mm or 38mm fit?
C'mon I know there's got to be a few people around here running this engine
i dont see why you couldnt use the m2c traxxas setup,i mean i got a stock traxxas flywheel assembly to fit and work so why woulnt an after market setup do the same @Kyleb if you want pm a email addy and ill sling you some photos,i can't get a pic on the site for some reason
