minmax89
- Thread starter
- #21
Any internal OWB gets soaked in oil, they even come greased from factory. The issue is the roto starter as it will hammer it until it cracks and then starts slipping, put a new owb and pull start on it and the problem probably won't happen again. As for the fuel... see if he will mix you some 5% castor and 5% synthetic MAX, they will probably argue with you but that's what I would run as 18% is just overkill and is best left to the planes. You may be able to get it to run but it will not perform to it's potential with that much oil.
Could this high oil content be the reason the engine is getting bogged down and cutting out?
