JESUS, just roll it on the carpet and tell us if it rolls smoothly.
It's not that hard to follow simple instructions.
If it doesn't roll smoothly, then one of your diffs is the wrong way around. (yes, do correct it before you run it)
If it DOES roll smoothly, it's fine, just that something may be binding elsewhere - example, spur. If the spur is stopped from spinning by something (tight gear mesh etc) then that center diff is going to be permanently engaged, hence when you turn one set of wheels (f or r) the other spins in the opposite direction.
Check the spur is free to spin smoothly, and if it is, get some oil in the center diff and give it a shot again. Should be fine.
Correct me if I'm wrong (I just got up) but i'm pretty sure thats how it is.
uDi
