markaagent
Looks like we demolished the driver side from suspension take a look suggestions links all welcome thanks!
Now don't take this the wrong way @markaagent
but YESSSSS. Now that's bashing.
I'm sure you are bummed about it but I actually love it when stuff breaks.
That gives me something to do.
I have the Typhon Mega but highly modified to run 4s.
I run it on 2s because she loves it that way.![]()
Short stretch idk not sure maybe about 30 ishNoice! How fast were you going? Bet it was badass
Just a newbie and maybe too another newbie, don’t let the shiny aluminum fool ya, don’t think it’s will be your friend…something nice aluminum
Exactly what I needed you are awesome! Thank you!Don't go with aluminum arms. You will break the bulkhead, hinge pins, etc.
Looks like you just need a shock, a-arm, and a steering link. You can get shocks at jennysrc.com pretty cheap, unless you want to upgrade to better ones. If so, look at the shocks for the TLR Typhon. No idea if they fit, but if they do, they should be good shocks.
Your steering link is bent in case you didn't catch that.
No need for aluminum.No need to go after the back end either. The fun part? when you break something you will learn how to fix it. With my 1st rig a Hoss, I broke an A Arm almost every time I took it out. Now never.Short stretch idk not sure maybe about 30 ish
BUT YES! We’re actually excited not too bummed! I know we need a new A-Arm but I’m not sure what those other parts are called I’m thinking of just redoing the whole front and back suspension something nice aluminum? Go stock? Is there a guide somewhere?
No problemo. Make sure you check your servo saver, which is mounted on the servo. It may have sprung and cracked with such a hard hit.Exactly what I needed you are awesome! Thank you!
Stay away from aluminum A-arms. Plastic returns back to shape instantly after a hard it, aluminum bends.Short stretch idk not sure maybe about 30 ish
Shhhhh people here like plastic!!Short stretch idk not sure maybe about 30 ish
That's because it's dumb to put aluminum arms on a basherShhhhh people here like plastic!!
