typex_rs43ss
Gone - bye bye.
just installed the cvx in my ss, no problems at all (except flywheel being stubborn, easily fixed).
when i first start my car, it idles fine, but after a minute or so, the car starts to slowly creep forward.... is it because my clutch is engaging early? if so, i heard the solution is to turn the screw inside the transmission... how many turns should it be? is there anything else i should check/fix?
also, i have to open the throttle a little less than 1/4 of the way open to get it started, but that makes my engine idle too fast and the car wants to drive off, but if i close it up a bit, to where the car wont move by itself, the engine cuts off after a minute or so... i'm lost one this one....
it makes sense to me that these two problems are caused by the same thing, just hope i can get a solution... thanks for the help.
