CharliesTheMan
Gone - bye bye.
Well I thought everything was ok, but apparently I have some serious water damage on my electronics. You can read about what happened in my tough as nails forum. Anyway, I dried the electronics to the best of my ability Later, I put everything back together to see if they were working. They worked for a few minutes, but then one of the servos started to jerk a few times, and then it didn't respond to the transmitter and would show no sign of getting power. Before things got wet and after I dried them for a while, when I turned the power switch on the servos would "come to center" as I call it, but now there is no sign of any power when I turn on the switch. When I took things apart, the receiver case was holding quite a bit of water, and the servos all appeared dry inside. Would a bad receiver be the problem? Is there a way to test the receiver or servos with a voltage meter or something?
