the mt2 comes rtr w/rotostart.
This is a 1/10 scale glow powered, radio controlled, 4 wheel drive
HPI Nitro RS4 MT2 off-road ready-to-run truck.
FEATURES: Chassis: 0.098" (2.5mm) thick 6065 aluminum purple anodized
countersunk
Drive: Four wheel drive
Drive Type: Shaft driven
Engine: HPI Nitro Star T-15 with ABC construction, dual needle 5.5mm
rotary carburetor, lightweight aluminum connecting rod, large
heatsink head, glow plug, and electric Roto Start engine starting
system
Exhaust: Aluminum exhaust header with dual chamber tuned pipe
Radio: Airtronics 2-channel AM pistol grip, with dual rate steering,
charge jack, steering and throttle trims, servo reversing, and two
SX-1 servos
Fuel Tank: 2.5oz (75cc), flip top cap
Clutch: 2-shoe
Transmission: Single-speed
Ball Bearings: Fully equipped, 18 total
Shocks: 4 oil-filled, composite bodied with coil-over spring
Main Gear: 52 tooth, plastic
Gearbox: Sealed front and rear
Differentials: Planetary geared
Brakes: Single, fiber disk
Tires: S compound Geolandar style, 2.2" (56mm) inner diameter,
4.05" (103mm) outer diameter, 1.98 (50mm) wide with inner foams
Wheels: Chrome finish, split 5-spoke 2.2 (56mm) diameter, 2.0" (51mm)
wide
Body: Pre-painted pickup stadium truck style
Bumpers: Front, plastic
Suspension: Front and rear double wishbone
Camber Tie Rods: Fixed, non-adjustable
Steering Tie Rods: Fixed, non-adjustable
Steering: Bell-crank
Servo Saver: Included
INCLUDES: One HPI Nitro RS4 MT 2 rolling chassis with oil-filled shocks, .15
cu in (2.5cc) engine, Roto Start, tires, foam inserts, wheels,
12 tooth clutch bell, 52 tooth spur gear, instructions, pre-painted
body with rear wing, 2-channel radio, glow plug, and decals
REQUIRES: Radio Batteries: 12 AA size
Battery for Roto Start: 6 cell 7.2V
Charger: For Roto Start battery
Glow Starter: 1.2 volt
Misc. Items: Fuel bottle, building and track equipment
Fuel: 2-cycle glow fuel with 10%-15% nitromethane, 16% lubricant-
Most of the fuels we carry meet or exceed the lubricant content
required for optimum performance and maximum engine life. In the
past, the conventional lubricant content used in fuel was 18%. But
with new advanced technologies, fuels like Red Alert and O'Donnell
for example, have a better quality of lubricants even though the
percentages of lubricant content are lower. These high-tech
lubricants provide exceptional cooling and protection.
countersunk
system
SX-1 servos
Clutch: 2-shoe
wide
