Any job is a breeze if you have the right tools. The wrenches mentioned above are fairly inexpensive and will keep you from destrying your rig and make things A LOT easier.
I use a pair of large channel lock pliers to hold the flywheel. It marrs it a little bit, but not to the point of being unusable. Once the nut is off, I use a small gear puller and a crescent wrench.
Just as mentioned above; say no to piston lockers, or any kind of conrod holding tools.
i just hold the flywheel with my hand and take the nut off with a 1/4'' rachet, the flywheel holds just enough on the shaft to break the nut torque witout slipping
If the flywheel loses its grip before you can un-torque the nut, stick an old toothbrush down the carb hole (remove the carb first) and jam it in the hole in the crank. That way you won't damage anything
