new engine, and my cluch just burned out so i have to buy a new one, and i tuned it like you said and when it runs good its to hot and when its just a click on the lean side it is slow.People say 20% keeps the motor running fast and cools the engine more cause of a higher oil content? is this true?? will it help??rocknbil said:Other possibilities:
Too high an idle, causing clutch to stay over-engaged
Tight gear mesh
Binding anywhere in drive train
Engine on it's last leg
Air leaks
Damaged glow plug gasket
incorrect temp glow plug
but usually, it's tuning.![]()
AC48 said:Yes, the higher the nitro content the lower the temps as a general rule. The downside of this is the higher the nitro the quicker your engine will wear out becasue of the higher compression. Most people find 20% Nitro to be the best balance.
When you say it is slow a click on the lean side, do you mean rich? Usually when a enigine is too rich it boggs and is slow and when it is hotter and runs faster, but will sometimes starve for fuel and it will wear out faster.
If one click makes a huge difference, then you could have one of the thingsd that rocknbil posted. You said you burned out a clutch, this shows that your idle may be too high and will need to be lowerd. If you leave your throttle servo at neutral does the vehicle roll at all, or does it not move? At neutral the vehicle should not move. The engine should be spinning slow enough to not engage the clutch. If your engine never gets a chance to idle and cool off some this could be part of your problem.
Sorry I missed this eariler.aj200415 said:....and my cluch just burned out so i have to buy a new one ...
parris001 said:Here's my reasoning.......... More nitro creates higher compression, right? ....
Sorry guys, nitro is power. And power if not harnessed is just excess heat.
AC48 said:You siad that running higher % Nitro allows you to run richer, which means more uncompressable matter in the combustion chamber.....
