This is probably the first evidence I've seen which supports an issue I experienced and most folks do not believe me when I share my experience.
Back when LiPo's first came out the C ratings were very low making IR far more volatile and unfortunately, IR checking wasn't a thing back then so I had no clue what the health of my batteries were other than age. Average lifespan was about 3 months for a battery before they started to swell and crack the casing. That was my indicator to replace a pack which is very sketchy.
Anyway, I replaced one of my 2S packs that had severely swollen with a brand new pack that was unmatched with an aged pack that wasn't swollen. Different brand battery and different C rating though same capacity. I think the old pack was a 25C and new pack was 20C, I figured it was "close enough". Everything seemed fine for the 5 min quals, but the 10 min main would cause the brand new pack to swell up and crack the case on the very first race day!
That would be the last time I would ever run 2x2S in series.
Fast forward 10+ years to today with 120C as industry standard, I don't think running packs in series is quite as dangerous as it used to be, however I have taken temp readings on a friends saddle pack after a long main and one battery was 20°F hotter than the other pack which was enough proof for me to understand that packs in series causes more strain overall and will require your batteries to be replaced sooner.
I would not recommend running packs in series without checking the IR at the end of every charge cycle, this will give you peace of mind.
