Wow! I've finally got thru a good amount of your vids. A lot of good info! Curious if you've got a chance to really run these kits side by side and if you're results are as positive as they look on paper etc... Also got to see the 'wall of flight'... Looks like a lot of fun hanging up there!
Hey Mike,
Thanks for the compliments, (bows head modestly) I'm trying.
The wall of flight needs more! lol I think a scratch built motor glider would round it out quite nicely. And I used e-calc the other day to try to put together a 90mph plane powerplant for a second aircraft. I'm not sure I'll be successful with it but I'm going to give it a shot anyway. My son needed something to do that day so I let him run the camera. Not bad for his first time, but my mini tripod came in today so I might start letting him help me out more with 'other" lol.
As for running the cars side by side, I don't have a partner to do it with today, but the weather is going to cooperate so I'm going to take it out to the community college today and give it a "post mod speed run" and hook it up like the last time, with the gps and all, then throw it up on the channel sometime this week. All I can say for sure at this point is that I ran a full pack that night in the video and the temps were perfect. and the bumps in the street kept sending her airborne and upside down (hence the run to the skid pad today)
I called horizon hobby and told them what I did and had to coax the answer out of the ground team that I was expecting which is that the 3800 does have more torque than the 4500, so already it'll be more efficient and probably run longer. I couldn't get a definitive answer on running a 3.25" vs a 2.75" diameter tire aside from what essentally amounted to "you might have to put on a 12t or 13t pinion if you want to keep the heat low." And I couldn't find any simple math regarding tire size / torque comparisons that didn't apply to full sized cars or industrial machinery. Rolling resistance doesn't interest me etc. At this scale, and weight, I just need to ballpark it. I suppose I can just go back to the run it for 5 minutes, take the motor temp, another 5, take the motor temp, etc, and if the taller tires make that big a deal, I'll have to drop to a 12t pinion gear to get my numbers back to what was in the chart. I added a section that tells my mph based on the circumference of the tire. The Equation is (Tire circumference x axle rpm x 60 minutes in an hour) / 12 inches in a foot / 5280 feet in a mile. It comes very close to actual given a speed on the chart of 23.4 mph, and the gps results of 25mph, and then factor in the gps fudge factor and and we're right in the ballpark. Regardless, 2.2" rims with pre mounted 2.75" diameter tires are plentiful and cheap on amazon so I might just stick with those.
