My jato upgrades and with 1/8 buggy wheels/tires. (photo intensive)
olds97_lss
RCTalk VIP
Dekalb, IL
Just thought I'd post these up. It's not a 3.3, just the body. Got it off ebay...
It's the old 2.5 jato with the non-ano'd head. It has my 18TM in it though.
How it was with pro-line gladiators and edge tires on TRX 2.2 rims:
click here
How it is now:
Moab's on the rear, road rage front:
Click here
Road rage all around:
Click here
I also installed a 3 degree rear pivot plate vs the stock 4 degree... I wish they made a 2 or 1 degree. Since I'm a basher, all that extra angle does is cause tire wear and takes off speed with sticky tires.
The upgrades:
JR 590M t/b servo
TowerPro MG995 for steering
Resonator single chamber pipe (jato 3.3 pipe)
RPM arms
RPM front skid
New Era 17mm adapters
OS 18TM w/pull start
Hot racing brake arm
Bearings in steering bell cranks
Bearings in brake pivot
I also made a steel plate to help support the front tie rod ends in the front bulkhead. I did the same for the rear, but it's wasn't nearly as straight forward/easy to make. I'm also running an associated spring secured header. I have a new stock one laying around in case I want to install the 2.5 back into it for fun.
By adding the buggy wheels/tires, it feels like a lost a lot of rotational mass. Attitude adjustment in the air requires much more drastic inputs. But, I added significant ground clearance for on-road/skate park purposes. The pro-line 2.2" on-road tires are much shorter side walled than 2.2" off road tires. The 1/8 buggy onroad tires are a hair larger than my 2.2" off road as are the 1/8 buggy offroad tires/rims I have.
I really like how it feels with the buggy rims/tires. I lost wheelies (thank god), but I gained more ground clearance in general and it seems to react more quickly to throttle/steering inputs. It takes off so fast now off the line due to getting wheel spin vs wheelie when I apply a lot of gas.
It was pretty cold yesterday when I ran it (42F) which made the on-road tires almost useless even on concrete at the skate park. I had to really feather it to get it moving. The moabs did a much better job on pavement and in the grass.
I have a set of badlands on my X1 buggy... which may find their way to the rear of my jato in the near future.
I'm also glad I don't have to keep 3 types of rims/tires on hand anymore. Just 17mm buggy rims/tires for my buggy and jato, and 14mm maxx sized rims/tires for my LST.
Here's the street tire/wheel comparison for size:
Click here
And all the tires/wheels for size comparison:
Click here
My front brace:
Click here
Rear:
Click here
And also the new aluminum brake arm:
Click here
I couldn't believe the difference the aluminum brake arm made. I actually had to adjust my linkage and my EPA considerably. Now I have room to move as it wears the disk! Before, I was at almost max EPA and had the brake adjustment so close to the servo that it was causing a very light bit of drag brake. I had been fighting with the brakes on this thing since I got it. For those of you with the same problem, start with an aluminum arm like I got! They are pretty cheap and really make a difference.
Anyone else get the 17mm adapters? If so, how did you like it?
That looks like a kick-ass jato Olds. So how is it in speed? With that engine can it keep up with the 3.3? And I really like your buggy tires on it. they look good.
I have it geared as low as possible... I think. I'm not big on speed, but it's fast enough to be a handful. Rarely do I hit second at my skate park, it's dinky.
With the buggy tires, it's much more controllable at higher speeds. Reacts much more quickly to brakes/turning than I'm used to.
I'll get a better feel for it when it warms up outside. Cold rubber, cold cement = bad grip.
I put the tyres off my Stampede onto my Jato.
No traction on tarmac, at least for the first tank. But it does have a slightly bigger rolling radius. But I couldnt tell you if it goes faster. (does it need to? Really)
yhea I got them and a front bumper. Now I need a hump pack and I was going to get a pipe. But I have been told the 3.3 jato pipe is a good pipe?
I can't say if it's better or not than anything else... I had the stock pipe on it for a bit with the original 2.5, then I installed an associated "tuned" pipe (old rc10 pipe I think) and I finally won a 3.3 pipe on ebay. With the 18TM in it... it makes it hard to tell if it's performing good or not. It's fast regardless what I do to it.
is that a stinky sock i see on your engine? lol
Not stinky... it was new at one point. When I took those pics, I had been running in 50F degree weather. The sock was to help keep the temps up to avoid running too lean. Works well until it gets wet.
i was just messin with you Olds, looks great. i want to put some buggy rims like that on my revo, like they have on the platinum edition.
Yeah, I know.
I thought the same thing back when I had a maxx. I thought it would be kind of cool to do it... but I never got around to it. On a jato, it really is nice in the handling department.
I just gut a fistful of new bearings from fasteddy.com. Hopefully they will hold up better than the avid's I used on the axles. They only lasted about 3-4 outings and are now all wobbly and loose.
