Motor temp
James nichols
What is safe motor temp? When should I let it cool before running again?
if you can't hold it for more than 3 seconds it's time to cool down. I use a air bed blower to cool down between races.
Unfortunately I'd have to use private areas to do that lol. I've got a bunch of nerve damage throughout my body and don't have feeling so that method wont work. I use a temp gun to judge heat so om looking for actual temperatures
The ESC should shut down at around 200 so a safe temp would be below that if I used a temp gun I'd shutdown at 165 for elec. If your running hot you may consider dropping 2 teeth in your pinion gear. and please for all involved DON'T use private parts on the track;)
If you're talking about the motor, 160 is safe. Fans are available to mount to many trucks.
I’ve got a temp checker I used for nitro rc, I think around 60•c is about the highest you want to be at you could try Gearing down May help ? I've just procured a Losi scbe last time I bought and sold it it had the dynamite fuse motor which got hot. I bought this as a roller and shoved a surpass hobby 4300, but it whipping the Arse out of the battery run time running 16t pinion I gone down to 14t it seems to running a bit longer. And cooler .
But make sure it doesn't slide down and start rubbing against your center driveshaft, that'll scratch it up and make it overheat faster. It happened to me
I think 180F is the upper limit and you don't want to be there long as it damages the magnets. I have mine geared and with fans to stay below 160F most of the time even when it's 80F outside and I'm running it hard. I use a temp gun to keep an eye on them.
I got one of these not to long ago as the one I have been using is 15+ years old that I got from Radio Shack for $60.
https://www.rcjuice.com/tools-accessories/accessories/hobbystar-ht-101-infrared-thermometer.html
The old one I have:
I also use a temp gun. I read it after every battery to gauge where it's at. At about 150 I start watching it closely. At 165-170 I shut it down for a bit to cool off
partsmgr
11
partsmgr
partsmgr
aklimitless
1
Hammer Down
Hammer Down
3
Ramp addict
Ramp addict
yfzracer450
3
TRAT
