Mini-T slipper and differental adjustments
civicclutchh22
stillwater
I have a Mini-T with a Baja engine and i have upgraded to the dual pad slipper and got a ball bearing differental but i dont know how and why to adjust them.i jsut have them set at what they were set to as in the intructions,but could some1 help me and tell me when i would want to adjust the 2.
does ur mini-t "click" when you press the trigger or a burst of sudden acceleration, my neighbors does
I will try to help you... I keep my slipper about 1/4 - 1/2 from being tighten all the way. As for the diff I have never been able to keep one hole. I have been told that you should be able to spin the wheel and the other wheel should spin the other way. Not sure if it is the same but on the XXX-NT you can check the setting of the diff by holding one tire, and the spur gear. Then take the one wheel you are not holding and try to spin it. IT should be VERY hard to spin.
