332_RC
Bashing/On Road/Crawling
Rig of the Month Winner
RC Showcase: 14
Need a plastic welder. Or you could use a dremel w/ the material in a collet & the RPMs would be enough to fill those dishes. Then file / sand smooth.Time to remove some goo. I start from left to right.
First step, prep a stick of basswood into a chisel.
Soak the area with WD40.
Scrape with the chisel to remove most of the big stuff.
The WD40 will actually mix with the goo. Once you see the goo and WD40 become one, clean with a paper towel.
Repeat a couple times. You will feel the chisel glide over areas where there is still goo. Work the WD40 in til you feel the chassis' texture with no gliding over goo.
Then wipe it up.View attachment 221512
The scratches you see above are from a screwdriver, which was done by someone before I got this. That is precisely why I use a piece of basswood. It doesn't mar the finish at all.
Spray on some Super Clean degreaser and scrub with a paper towel or shop rag. Or you can use some Superman tighty whitees
And abracadabra. Good as new, after someone carved into it with a screwdriver
Next up @Littlemotor - doing "dishes"![]()
