So I'm loading up a body right now with a few coats of parma liquid mask that I'm about to start painting. My question is once I get the parma all on there and ready to go do you cut all of your lines before you start painting? Seems like if you only cut out where your first color is gonna go (in my case black) then I wont be able to see through parts of the body where I have the lines drawn on the outside because it will be covered up by black paint.
On the other hand if I cut all the lines ahead of time then it seems like paint is likely to bleed through the cut marks. So how is this done when you have a some what complex design where you have 2 or 3 colors all going in the same small area?
