Kronos xtr first 6s run, complete failer
Caleb90
Up state
Did my first 6s run. Lasted about 5minutes. Thing is stupid fast, hard to control. Snapped the front drive shaft, and cooked the center diff. Seemed to have alot of cogging off the start. Truck would jump and bounce, go no wheres making a racket. Then it would finally get going. I just put over size tires on, so i will try gearing down i guess. I also lowered the timing to help with heat, might have to bump that up. Pretty dissapointing afternoon to say the least
Center diff is my fault for running with out the front drive shaft. I assume the front drive shaft broke due , to the goofy angles corally uses on there drive line. Causing the front diff cup to wear a groove in the shaft. Returning the tires due to them being to heavy, and the one rim shattered after looking them over better. Have better sized tires in the mail now
6S tends to tear up kits that werent specifically designed for it. Took a lot for me to get my Losi LST2 electric conversion to hold up to 6S and it still ocassionally breaks stuff. Sure is fun though :)
center drive is from not lowering pinion gear after adding the larger tires thats what killed front ds and mid unit
While that did contribute, the front diff cup was wearing a pretty deep groove on the shaft. I'm going to need to add a oring or somthing to help push the shaft back so its not at such an angle. Returning the tires and have somthing better sized in the mail now
https://www.corallyforum.com/threads/shaft-center-front.567/
The kronos isn't a 6s truck? Glad I didn't get one now lol.
