- Thread starter
- #21
osrocket said:here is a litte input since i am being referred to, if it was overpinched the first thing i would have done is email osrocket and he could relieve it the same as ray!!!!!
the pull start RG engines are one of the harder to set for the pinch because there is very little pinch to begin with and all the guys that i do like them extra tight so they last longer, yes you may have to replace the 12.00 rod, but if it is in need of a pinch the rod is questionable anyway,
also the squeezer ring is garbage as anyone will tell you it makes them out of round, you may as well trash them after that,
i started this 6 years ago approx. 2 1/2 years before ray came up with the arbor press and slug deal, and i did many for him before that, and i do it on a cnc controlled machine which is highly accurate, but most important is my service is perfect and all guys will tell you that from experience, And when we attend the big races (200 plus entries) matt(my son) usually always makes the A main in 1/8 buggy expert and also 1/8 unlimited truggy, running O.S. engines that have been pinched and polished , not modified. Again you will never hear that i have not taken care of any of my customers all they have to do is ask, thanks johnb (osrocket)
email is [email protected]
First off, I apologize for anything I stirred up.
I figured it was normal as it was my first pinch job. I don't doubt your ability or your work. I can vouch that the pinch is tight. I've just never had to deal with that tight of an engine before. It was a tough learning experience. All the info I found was basically to use a starter box... the reason I got it re-pinched was due to saving money. Buying a starter box just wasn't worth it.
I think it's going to work out ok. I ran it this weekend in my buggy and it has a lot of snap now. I've run about 1/2 gallon through it since I started this thread. It still gets stuck at the top and I have to rotate the flywheel with channel locks, but as long as I start on the downstroke, it pulls over and starts just fine.
Next time I'll ask before I beat myself to death trying to "make" it work. I just figured for $20, you wouldn't really want to be bothered with it. I mean, you pinched it, tighter than it was when it was new. What more could I ask?
Again, I apoligize for any harsh feelings.
Thanks.
