Is this okay ?
Register Log in
superticky
Hello guys,
I was wondering if this is okay or if there is something loose I need to tight, or maybe something with the servo saver ?
This is me moving gently with my finger one of the wheels. Thank you !
D3MON
RCNT Talkaholic
Missoula MT
Bashing
what model? some are known for having some slop, that is quite a bit though. id follow the linkage back as far as stuff is moving and try to pin down where the slop is coming from.
D3MON
RCNT Talkaholic
Missoula MT
Bashing
rc10s usually have really tight steering, id backtrace the slop. let us know what you find!
olds97_lss
RCNT VIP
Dekalb, IL
Bashing
When's the last time you replaced the ball ends? My jato has pretty tight geometry, but almost any slop in the ball ends affects it in a big way.
HeavyBag
RCNT Rookie
That is quite normal amount of slop with the stock bellcrank. If you want to reduce a bunch of it (slop) you'll need the Factory Team steering rack and bearings. You'll still have slop, just less of it.
I've been running the T4.3 for two years now, and the slop in the steering started after I had put about 30 packs through the truck. The amount of vertical/horizontal movement in the steering linkage seems to have plateaued. I just throw the truck down on the track and let 'er rip.
