AuburnVFR
I’m a Newbie to the RC world, so forgive my lack of knowledge.
As the title states, I inherited a HBX 3100a truck with some issues and could use advice from the experts before blindly replacing more parts.
Issue: It does not consistently go into reverse. Most times, nothing happens when pushing the remote trigger forward (not confusing it with braking). Then after multiple attempts, it will reverse. It will continue at slow speed in reverse when the trigger is returned to neutral. Then reverse won’t work again. If the REV control switch on the remote is flipped, reverse works normally but now it does the same thing for forward.
My trouble shooting: It does the same thing when bound to a different remote. It does the same thing (using the steering wheel) when esc is plugged into steering servo slot on the receiver with no change. I tried a different esc with no change.
Bad motor? Bad receiver? If I replace the motor, should I get a motor/esc combo? Any recommendations for 2840 brushless 3800kv replacement? Are combo kit esc pre-programmed or will I have to program it?
thanks for any help
thanks for any help
