I prolly screwed this up already
powder_king
RCTalk Racer
i took apart my new mill and cleaned then i used engine oil to lube all the parts, will this cause any problems at start up
depends what oil i have used 3&1 oil in mine ,marvel mystery oil and tranny fluid mix wd-40
all depends if it was motor oil ummmm...might be way to thick for a nitro esp the plug to burn off ,,
just my :2cents:
it was 0w 40 so it thin stuff and i never seen after run oil so i can't compare but the stuff is a little thicker than cooking oil
You should be fine. It might be a little sluggish on the first start, but after that it will be fine. I've used straight 30w motor oil to oil my engines and never had a problem. Then I found out there's such a thing as after run oil, so I've been using that for the past few years.
