I need to fix a thing
WVNed
Vroom Vroom
Scott Depot WV
My wife broke that came from her parents house. I have to solder 2 wires to a board again.
How do I tell if it is lead free or lead based solder so they will stick back together. I don't know how old it is but it isn't ancient, maybe 10-15 years.
It's a solar wind chime on a stand her parents got for an anniversary.
leaded solder is between 5-70% tin + lead, lead-free is 95% tin + antimony.
use a solder flux or paste during soldering to remove impurities.
My Radio Shack rosin core worked fine.
Heat.... I recently bought the Hakko Soldering station Woodie recommended for my train project. Heat is not a problem now.
Thanks guys
I tried lead-free solder and it just created a mess because it requires higher temps before it melts and the flow is not as smooth
I prefer 60/40 with 0.6mm diameter like this:
https://www.amazon.com/gp/product/B075WTX9WY
If your solder is too thick you risk applying too much solder and may accidentally bridge your connections which is the problem I ran into with the lead-free solder :(
