1/10th bells/flywheels/shoes are thinner than 1/8th. Traxxas uses the same 1/10 2 shoe clutch in all their nitro trucks I've had. Jato 2.5, t-maxx 2.5, revo 2.5 and revo 3.3.
On my big block revo, I converted it to use a 1/8th sized clutch and used a flywheel/bell/shoes off a savage, which I later also changed from HPI teflon shoes to 7075 alloy. I had to move the transmission forward 1/4" so it would fit.
I'd do the same on my second revo with an OS21TM in it, but I'd need to get a crankshaft extension and give up my MIP center cvd's so I could move the trans. My big block uses traxxas plastic sliders for the center and they hold up ok.
This is from way back on my first revo when I had a 18Tm in it and had the crank extension before I moved the transmission to show how much it needs moved:
I had to grind the chassis to give it room to move forward, elongate the 4 trans mounting holes and once I had it where it needed to be, I drilled 2 3mm holes and put bolts/nuts through the transmission flange to key it to that spot. I didn't want it moving around.
Some guys didn't do that and just relied on friction to hold the trans. It was a bit of a pain to do. The center axles had enough material that you could do that without having to get creative with the center axles. The front would compress and the rear would extend.
Again, that was also just an
HPI savage 3-shoe flywheel/shoes/bell. I kept cooking the spring in the traxxas 2 shoe, so I went that route, then never had an issue again.
In my 21TM revo with the 1/10th clutch still in it, I replaced the shoes with dynamite max life aluminum, which are hard to find now. They have held up really well. Actually just finished a bash session today with it.
