olds97_lss said:
SQL? Is that a folder or you need to write an sql?
By 'sql' he means his databases which are the backend to most scripts such as vbulletin which runs RCNT. The problem is they are stored in /var/lib/mysql so you probably are not going to have the permissions to access it as an FTP user doing a backup. I am still looking for a solution for this.
I did find this however which may do the mysql backup also.
ABSOLUTELY keep this script out of your public_html directory.
// PHP script to allow periodic cPanel backups automatically.
// Based on script posted by max.hedroom in cpanel.net forums
// This script contains passwords. KEEP ACCESS TO THIS FILE SECURE!
// ********* THE FOLLOWING ITEMS NEED TO BE CONFIGURED *********
// Info required for cPanel access
$cpuser = "username"; // Username used to login to CPanel
$cppass = "password"; // Password used to login to CPanel
$domain = "example.com"; // Domain name where CPanel is run
$skin = "x"; // Set to cPanel skin you use (script won't work if it doesn't match)
// Info required for FTP host
$ftpuser = "ftpusername"; // Username for FTP account
$ftppass = "ftppassword"; // Password for FTP account
$ftphost = "ftp.example.com"; // Full hostname or IP address for FTP host
$ftpmode = "ftp"; // FTP mode ("ftp" for active, "passiveftp" for passive)
// Notification information
$notifyemail = "
[email protected]"; // Email address to send results
// Secure or non-secure mode
$secure = 0; // Set to 1 for SSL (requires SSL support), otherwise will use standard HTTP
// Set to 1 to have web page result appear in your cron log
$debug = 0;
// *********** NO CONFIGURATION ITEMS BELOW THIS LINE *********
if ($secure) {
$url = "ssl://".$domain;
$port = 2083;
} else {
$url = $domain;
$port = 2082;
$socket = fsockopen($url,$port);
if (!$socket) { echo "Failed to open socket connection... Bailing out!\n"; exit; }
// Encode authentication string
$authstr = $cpuser.":".$cppass;
$pass = base64_encode($authstr);
$params = "dest=$ftpmode&email=$notifyemail&server=$ftphost&user=$ftpuser&pass=$ftppass&submit=Generate Backup";
// Make POST to cPanel
fputs($socket,"POST /frontend/".$skin."/backup/dofullbackup.html?".$params." HTTP/1.0\r\n");
fputs($socket,"Host: $domain\r\n");
fputs($socket,"Authorization: Basic $pass\r\n");
fputs($socket,"Connection: Close\r\n");
fputs($socket,"\r\n");
// Grab response even if we don't do anything with it.
while (!feof($socket)) {
$response = fgets($socket,4096);
if ($debug) echo $response;
fclose($socket);
Remember to put the file with this code in your "home" directroy - not in "public_html".
And CHMOD it 600.
Then create the cron job, like this;
5 2 * * 6 /usr/local/bin/php /home/username/fullbackup.php
(=2.05 am saturday)
