The very first thing you need to do is PUT THAT AIR FILTER BACK ON AND NEVER RUN IT WITHOUT IT!
We know you're excited and just want to run the darn thing but take a step back and learn a bit about tuning. There's tons of info here and people will help you.
The HIGH SPEED NEEDLE (big tall one) meters all the fuel going into the engine. This is going to be where most of your tuning is done. The fuel is metered by the amount of vaccum pulled by the engine - that is, you adjust the fuel to the amoun of air being drawn through it.
The LOW SPEED SETTING is really only to adjust fuel input when the engine is at low to middle speeds. Rest to factory setting and fiddle with it ONLY if you get perfect tuning at mid to high speed and it is giving you trouble going from low to mid speed. Since you haven't even broken this engine in, that means LEAVE IT ALONE.
The IDLE SCREW (one with spring) is nothing more than a stop screw to prevent the carburetor from closing completely. This is what keeps it from idling so low as to stop the engine when it's tuned properly.
As has been mentioned, set everything back to the specifications in the manual, this is a starting point.
Now before beginning, take the air filter back off (I know what I said!
) and turn on all electronics with the engine OFF. Work the throttle and watch the opening in the carb. When you let go it should close to about the thickness of a credit card. If it doesn't, make SURE the throttle trims on the transmitter are moved toward the "brake" side. If it's still too far open, unscrew the idle screw a litle at a time until it closes up a little.
Now put the air filter back on and get it going. Proceed with tuning as you would - leave the "slow speed" needle alone, and adjust the HSN from rich to an optimum tune. If it still idles too high AFTER proper warm-up and tuning, let out the idle screw a little at a time until it idles down.
As I said there are hundreds of tuning threads on this board alone, all described and expressed differently - read some of them and you will ge the hang of what you're supposed to do for tuning.
