Do you have any tips
What color lines are receiver box with protector receiver
Can you attach pictures on how the servo horn and servo is hooked up. The high pitched noise is on idle or when it turns. And if it's during turning does it make the high pitched noise when it gets to the end of each end point of the servo?Having issues with the throttle servo making a slight pitch noise one Servo horn is connected and linkages is hooked up one Servo horns not on is normal how to fix it turbo don't burn up
In regards ....Some times a servo will make a hum or sound if its not in it neutral position after movement
from the controller!
May have to use transmitter trim inputs to cure the issue!...
